Auto numbering in Symbol.
Hello all,
Need to add functionality of auto numbering in any symbols variable text when set to integer type.
Due to this it will be easy to add balloon notes and other sequencing symbols in drawing.
This i am demanding the functionality same as the draft datum feature available from Creo 4, where datum feature is placed in sequence like A, B, C and so on and if user type the already used name it gives warning by red underline.
So same functionality we need for symbol numbering. This can be done by simply adding some kind of syntax in Creo. So R&D guys please work on it because we already have similar kind of syntaxes but in Datum symbols and Repeat region table (rpt.index).
Jignesh.
2 Comments
Regular Member
Did you find a way to do this?
Contributor
@NitMad
I created a symbol with variable text.
But everytime i have to change the number. Everytime i place the symbol, default number will come.
