The solution will be useful for Pro/Piping automatic bolt/nut insertion. Currently callout is not created for the information components, because they do not contain any geometry. The idea is to automaticaly create a callout, tied to parents (components that are used for parametric amount) information component.
Such a possibility would save a lot of time on the design drawing.
