Creo Parametric: 5.0.3.0
Module: Assembly
Config Option: open_simplified_rep_by_default Automatic Rep
REFERENCE: SPR 8112265
CURRENT ISSUES:
Automatic Representations are showing us incorrect geometry for family table models, old files and for models with assembly cuts. The message log shows that it knows there are issues with the graphical representation.
RECOMMENDED SOLUTION:
Option 1: When Creo has an issue with the Graphical representation, the software should automatically use master representation for that component.
Option 2: Fix Automatic Representations so that is shows correct geometry
See photos for specific issues and justification
JUSTIFICATION
