Automatic activation of a selected window
as of today, Creo 3, you still have cases where window isn't activated as should.
Automatic activation of a selected window is required.
3 Comments
lscheeler
Pearl
Can you describe the situation in which it does not activate the windows when you think it should?
From a brief test, I was pleased to see that Creo3 does NOT automatically activate the window when in the middle of a feature creation.  Prior to testing Creo3, I was concerned that it would autoA in the middle of a feature creation/edit and would prevent the user from comparing/reference models.  I am very glad that PTC did not impliment it this way...so hopefully you are not refering to these types of cases...?
vmcdaniel
Guest
Here is one case the window does not activate as desired.
http://communities.ptc.com/ideas/3284#comment-15523
I see that there is already an SPR 1890569 filed for issue and seems to be to closing as Enhancement request,
Please refer to Article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS9099 for more details.
Here is Article resolution:
  • Reported to R&D as SPR 1890569
  • Working to product specifications
  • SPR is still active but is considered as an Enhancement Request.
  • To be able to directly have the window active at retrieval of the object, prefer the approach >File >Open from Pro/ENGINEER (or Creo).
At moment this seems to “Working to product specifications”.
Let me know your comment otherwise we can close the ticket.
Vikram
Please see this video demo: http://youtu.be/VvqYmlHwrIs
PTCModerator
Emeritus
