Automatic assembly cross-hatch management.
In drawing when I create an assembly cross-section I have to change manually cross-hatch space and angle for any part. I think its possible an automatic mechanism that flip angle and change space for any parts. Now If I have 100 components it's an hard work!!
9 Comments
SamuelBrantner
B&W software has a little tool that will take care of that:
http://www.youtube.com/watch?v=y157GQYcj4I
FrancescoPompeo
11-Garnet
Good, but I think that Creo and PTC could do it its self, without any tool.
If B&W do it with toolkit, why PTC can't!
Thank You.
dhermosillo
Also, an option for not showing the cross-hatch lines at all, instaed of having to double the spacing till they can't be seen anymore.  Note, this is different from Exclude.
FrancescoPompeo
11-Garnet
I think this would be a useful function to reduce time to create complex drawing, so please vote it.
Thank You.
bduncan
PTC tends to ignore the details of the consideration
PTCModerator
Emeritus
Mfridman
Status changed to: Under Consideration
Mfridman
Status changed to: Implementation In Progress
Hi all,
We are in the midst of implementing some improvements to the hatching capabilities in the drawing side.  This includes an improved algorithm for automatically providing different angles and spacing for the different components that are sectioned. stay tuned for more details later
Mfridman
Status changed to: Delivered
Hi @FrancescoPompeo
Creo 9.0 introduced a major overhaul to the way that you can edit the hatching properties in your drawings.
There are many improvements that will make your life easier so you should check out the what's new pages:
1. https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/#page/whats_new_pma/drw_improved_usability_for_editing_crosssection.html#    (check out the video)
2. https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/#page/whats_new_pma/drw_hatch_tree_drawings.html#
3. https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/#page/whats_new_pma/drw_new_hatching_options.html  (pay attention to the hatching angles rotation logic and the "Recreate hatching angles" command - this is tightly related to this product idea request and it will take care of different spacing for each component as well
4. https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/#page/whats_new_pma/drw_hatch_designer.html#
Best Regards,
Michael Fridman
Creo Product Manager
