Automatic contact force component measures
0 Kudos
As part of contact QA, freebody force balances are required.
For this x,y,z, contact measures are required. Automatic Magnitude is not sufficient.
If there is only 1 contact then there is not much hardship other than human errors.
If one models a spline connection, for example, then there may be 10's - 100's contacts and human error will occur when creating x,y,z measurements, it takes considerable time and models that have many contacts take a long time to re-run ...
Could be switched via a config option or as a check box when creating the contact
Contact force components could be stored in a separate csv rather than cluttering the summary file
Have default recording in the WCS PLUS at least one other of the user's choice.
2 Comments
346gnu
https://community.ptc.com/t5/Creo-Parametric-Ideas/AUTOMATIC-COMPONENT-MEASURES/idc-p/767785#M15345
We should include:
CONSTRAINTS
SPRINGS
in the automatic measure creation
ToddKraft
Thank you for the idea submission.
Todd Kraft
Creo Product Manager
