When creating a threaded hole as standard hole in Creo Parametric using a *.hol file
the hole depth and the thread depth will be calculated initially with the following static formulars:
DRILL_DEPTH = 3 x DRILL_DIAMETER for example: DRILL_DEPTH = 3 x 7 = 21
THREAD_DEPTH = DRILL_DEPTH / DEPTH_RATIO for example: THREAD_DEPTH = 21/1.25 = 16.8
If the threaded hole was placed there is no more intelligence like this for further changes.
The only rule is that the thread depth can not be deeper than the hole depth.
If this happens the thread depth will be changed to the same value than the hole depth.
With this behaiviour it es not possible to create an individual hole depth (not every hole is 3 x DRILL_DIAMETER)
with an automatic change for the suitable thread depth.
It would be nice to have the following behaviour to provide a higher level of automation for the customer creating standard holes:
