Automatically suggest PATTERN WHEN ASSEMBLING component on a pattern
We would gain time if Creo could be able to recognize the pattern on witch a component is placed.
- Automatically suggest patterning the component when assembling on a pattern
- Add the pattern button or popup menu command in the assembly function interface
Filling patterns with the “Auto  Placement” is not a good process. If you change the value of the quantity of the reference pattern, the assembly will not update the correct quantity.
Reference pattern is what we need but directly when placing the component.
3 Comments
Amethyst
Good idea
Aquamarine
Thanks & Thanks 4 your vote (s) ...
Community Manager
