Dear Sir,
Recently my customer has come across the below small requirement.
1. The file path should be printed automatically on the drawing, once he add the parameter in template.
Since this facility is manual at this moment. Please add this as a parameter in the template for automation of this small.
Best Regards
Anil Pagar
