Since Creo 4 balloons have been updated to snap tangent or perpendicular to the object they are detailing.
--This needs to be updated to allow users to turn this functionality off.
It would be great if you could select other snap options as well.
--Allow users to select all snap lines and interface similar to the xsec line manipulation allowing for any angle to provide consistency and symmetry within drawings.
BOM items could be more easily placed initially.
--When placing balloons by view, snap lines could be shown to select what sides of the model new balloons will be applied to initially. (If we know we want them only on two sides of a view, starting with everything there would save time and we are not all using MBD so this is tedious and unnecessary).
--It is worth noting that drawings with many balloon items look like lazy amateur hour compared to drawings previously produced with CREO-- Please end amateur hour !!!
