When I want to re-order the rows in my BOM table the system does not give me the ability to do that.
Example:
I have a drawing from an assembly. The assembly has 10 parts. I add a table from "Table -> Quick Table -> bom description up". The items are sorted automatically. Now I want to move only the item 4 up and change the position on item 9. The rest of items would change accordingly. This is not possible in any way. The best would be select the whole row for item 4, press RMB and move the row onto desired position in the BOM table.
