BOM table in Annotation should count by subassy
I have a drawing of an assy and this assy contains subassys. The subassys contain parts, shared in one or more other subassys. When I create a BOM table in Annotation, it will now count all instances of the shared part, ignoring the assy-structure. I would like to have the option to count them per level (per subassy).
6 Comments
wdesmet
3-Visitor
then i think you should use the option 'one level' when scanning the model in stead of 'all levels'.
this way the scan wil only look down 1 level, scanning the sub-assembly and not the parts. or is this not really what you mean?
I also think the BOM functionality should be expanded, so multi-level BOM's are possible. kinda like the BOM editor in Model Manager.
ErnestSmit
1-Newbie
No, I really want "all levels". The shares in the subassys are intentionally organized that way and reflect some kind of assembly procedure. I need one comprehensive table of the top-level assy containing the BOM-information.
ThomasKirkman
After generating the BOM, then create a report.  this will let you expand all of your subassemblies. You can expand the sub assemblies and included or exclude the sub assembly.
It takes a little time to develop your best practices that best suits your needs.  Once you do, you can generate your bill of materials very quickly.
ErnestSmit
1-Newbie
I think your suggestion refers to the BOM-module, but I mean the BOM functions inside Annotation (without BOM license).
ThomasKirkman
You are correct.  I have not used the BOM functions inside Annotation in a long time.
PTCModerator
Emeritus
Status changed to: Archived
