Be able to bundle flexible pipe routes in the Piping module (similar like a bundle in Cabling)
Flexible hoses for pneumatics are often bundled using for instance tywraps.
It would be very convenient to be able to bring multiple routes for flexible pipes to one route, similar as is possible in routing wires with Cabling.
3 Comments
Contributor
Yes! I think one should be implemented various kind of "bundles" like spirals or other bigger hoses.
Moonstone
This idea seems to be quite similar to my idea "Improve spec. driven piping for enhanced handling of hoses (flexible pipes)", doesn't it?
Contributor
The topic may links the first point of the thread you said. In the sense that first you need the possibility "to route two or more hoses based on another hose" (as said in the other thread), and then you might have the new "wrapping" feature.
