Be able to define a sorting preference when selecting references in sketch mode (config option ?)
When activating a component in assembly and taking references in sketch mode (when several edges or surfaces are coincident), it would be GREAT that the system would :
Prefer / Privilege active component references before other component
Prefer / Privilege intent references
Prefer / Privilege vertical surface references rather than edges
  1. Active component intent
  2. Active component surfaces
  3. Active component edges
  4. Other component intent
  5. Other component surfaces
  6. Other component edges
3 Comments
NicolasBourgeoi1
I dont want to limit the selection to the activated component.
NO:     default_ext_ref_scope  none    &   ref_control_allow_exceptions  no
NicolasBourgeoi1
Need to select activated component entities from the sketcher when geometry is adjacent / overlapping the geometry of another component
olivierlp
Community Manager
Status changed to: Archived
