It would be great to be able to use the model tree research with parameter displayed in column like we can do with the component name
The research should ask in which column it must look
If you use the normal find tool (ctrl + f) you can search for parts where a parameter contains a portion of text as the criteria.
when you highlight or after you add them to the selection list they will be highlighted in the model tree!
This has been delivered (with Creo 5.0)
