Be able to show the dimension value @D and its dimension name @S in the same dimension object.
According to PTC document CS138583 is not possible to have both dimension name and its value in the same dimension object so we would like to request this to be added in future release as part of our process require to have that information in the same object.
Note from PTC document:
Note : Both the dimension value (@D) and its name (@S) cannot be displayed at the same time in a single dimension object. It is possible to add a first dimension through Show annotations option, display it as a symbol (@S) and then add a second dimension manually referencing the same entity to have the dimension value displayed.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
