Beam measures for
STRESS - tensile, bending, torsion, total
are the only beam measures available.
Forces and moments can be found using the post processor but this can be laborious if there are many beams
... Display the beam's shear and moment diagrams, write the number down, make mistakes
or
Click on a beam fringe roughly where required making sure the correct beam is selected if there are many and the view is complex. Then change the quantity to the next force/moment component. Write the numbers down. More mistakes
Not having beam measures rules out useful sensitivity studies.
