Bearing Load boundary Condition in Creo Simulation Live
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
PTC partner on behalf of a customer desingning earth moving machines ( excavators, cranes, etc.)
2. What version of Creo Parametric are you currently running?
Creo 7.x
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Creo Simulation Live does not provide a boundry condition describing the bolt load on a bearing
4. What is the use case for your organization?
Most of the parts of the machines designed are connected by bolts mounted in bearings. The boundary conditions availlable in Creo Simulation Live are not siutable to describe this special load situation.
5. What business value would your suggestion represent for your organization?
Bolt-Bearing connections cannot be simulated in Creo Simulation Live in a realistic manner
2 Comments
olivierlp
Community Manager
Thank you for your idea and the information you provided.
olivierlp
Community Manager
