In Creo Parametric sheetmetal, there is a really good feature that allows the user to identify bends and give a sequence number, that then gets created as Model Dimensions for the drawing.
Unfortunately capability is not available in Creo Elements/Direct Modeling Sheet Metal, but it would be a very good addition to the module.
