Best method for adding geometric tolerance to tapped holes dimension in drawing?
Placement of GD&T frames should be allowed to be placed below a note (especially a hole note).  Just adding &gp{#gtol#} is not sufficient, because there is no semantic query, and you cannot then erase the standard GTOL display without also erasing the hole note from display
2 Comments
DaveHeipel
6-Contributor
Limiting the attachment of the GTOL to the flag instead of the note seems to have been done on purpose. What that does is prevents the user from using the notes defined in the hole tables and forces them to display the hole dimension and manually create a note around it. A lot of extra work.
olivierlp
Community Manager
Status changed to: Archived
