Better Handling with Patterns and ECAD/MCAD Collaboration
0 Kudos
When a proposal from ECAD requires a movement of a component, which is a pattern member, a warning is shown on the screen - Cannot preview/commit changes on pattern members. Different issues occur as well when the proposal involves moving an instance. We use our components to reference panel cutouts with other children references as well. We can't have pattern components failing or patterns deleting. The most obvious/easiest workaround that I can think of is simply to convert the pattern to single components with the same internal IDs that won't fail any children. Please help with this as this is critical to our business and it will be hard to move to ECAD MCAD collaboration without proper support to patterns.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
