When using Creo linked to Windchill users do not have a readily available way of knowing the status of the Windchill link to their Creo Session.
The best example of this is when a Creo check-in fails. The failure message only shows up in the messages at the bottom of the Creo page and the well-hidden Event manager. It would be a benefit for troubleshooting to have that fail message in an obvious place.
Possibly give the users the option to put the event manager, or some other Windchill dashboard, front and center so they can monitor the status of the Windchill connection to their Creo session.
Bob Lohbauer
Medtronic
