Boxed Text area in drawing.
Today it's works with the tips @[  ]@
Why is it so hard ???
Add a easy solution to create a boxed text.
3 Comments
Dale_Rosema
23-Emerald II
One thing that is nice about the @[ @]  for putting the box around a portion of the text. This works when using notes on a drawing, and you want to designate special instruction for a particular note or you want to flag it on a drawing.
PTCModerator
Emeritus
Mfridman
Status changed to: Delivered
Hi there,
It is already possible to start the box formatting for a note text by picking the "Box" command from the note ribbon:
In addition, you can start and end the box formatting with the new shortcut of "Ctrl+[" as instructed in the command tooltip
