We need the same functionality for std Creo CAD objects(asm&prt) that a Bulk Item has when it comes to units and qty and link to part structure in PDMLink.
Std Creo CAD objects has only each capabilities on the link from ProE to WT-parts structure in PDMLink.
Bulk Items has the capability to express other units than each like m, kg with link from CAD to WT-parts structure but no geometry.
I would for example like to assemble one Creo CAD part (prt) with 60cm Fuel Hose and get 60cm Fuel hose and not 1 each as it will be today with the geometrical representation in Creo View.
BR Magnus
