Butt weld should go to the end of surface
0 Kudos
Tried to weld two parts together.
It seems that the geometry is not that simple.
With a butt weld it works but if I trie to fill the gap completly
when I try to fill the gap completely with a butt weld it does't work like expected
It's depth is 14mm and it works only when I type in 13.99mm
It's possible with this workaround to type in 14mm but you have to define a face offset of -0.01mm that it works
Not so nice for users to find this workaround.
Is there a possibility for the programmers to make this easier?
