2 Item's must be changed in future Release for DXFDWG / SVG-Konverter
- the Conf-File must be separated because DXFDWG and SVG using different Values for example Font-inclusion.
In dxf-Conf I need the filename (finding in the font-folder of Windows) for the specified font
In svg-Conf I need the name of the font (showed p.e. in Adobe Illustrator). This meens, I have to copy the Conf-File but in
- WIN7 it isn't allowed for a user to modify / overwrite files in the program-path. So it must be possible to search the conf-file first in a folder which is accessible for everyone. Maybe there is an undocumented environment-variable DXFConfDir available?
