CREO 3D PDF Export Template for MBD
it would be great to have a way in Creo when exporting to 3D PDF that we could set the different combined state tabs to be on separate sheets.  Also, if there was a way to set up the 3D PDF with a template that had our company information already setup similar to a drawing template.  This would allow us to put common notes, tolerancing, and company info in without having to add it every time we created a file.
4 Comments
hostroske
The export of a 3D-PDF must be much more comfortable. Following "State of the Art" like other CAD systems like SW or NX are doing. Combined views and their annotations must be possible to export. There should be a possiblility to predefine PDF templates for the export.
Mfridman
mfischer
18-Opal
Status changed to: Under Consideration
Hi all,
This idea is on my roadmap for a future release of Creo.  The plan is to overhaul our 3D PDF export to support template based PDF export, including defined MDB information.
Mark
TomU
@mfischer,
Please make sure that when this is added to Creo, the CAD workers are also able to output the same thing (using Creo).  Thanks!
