Being new to CREO and this community I have searched for solutions to issues we are having. I have found it confusing trying to find solutions with so many posts for the same issue. I have submitted 2 other posts that describe all of the issues we are having. It wass suggested that I break these long posts into smaller ones.
My original posts are here:
https://community.ptc.com/t5/Creo-Ideas/Some-CREO-Drawing-Enhancements/idc-p/485687#M9775
https://community.ptc.com/t5/Creo-Ideas/Some-CREO-Enhancements/idc-p/485686#M9774
I am not even sure if this is the location for CREO enhancemments or iif the PTC folks even read these.
I apologize in advance for any duplication.
Pleae add to this if I have imissed anything.
Drawing symbols (including REF Balloons) cannot be related to another object, like tables and different symbols.
Allow Drawing Symbols to be able to relate to other objects. This will help to reduce the errors when a table is moved and the symbols do not.
It is currently difficult to be able to change the properties (thickness, style, color, etc.) of drawing elements like lines and circles.
Allow the user to change the Drawing elements properties.
Creating a Drawing Symbol, or adding drawing lines and circles on a drawing sheet, is a laborious process. Creating simple things like a line or a note seems to take a lot of steps. Trimming elements to a common intersection does not seem to be intuitive.
Modify the Symbol Creation window and adding drawing elements to work more like Sketcher in a Part.
We cannot create a link (Relate to Object) to a table.
Allow a table to be used for the Relate to Object command.
