When copy command is applied to an assemblies that contain some stock/finish relations all this relations are loosed on the copied assembly.
In the actual release there is no way to maintain the stock/finish relations (see case 11717210)
The customers ask for an option on the copy command that if selected can include the stock/finish relation in the copy operation.
Best Regards
Dott Franco Mazzucchelli
