CREO SCHEMATICS - TERMINATOR TABLE. INCREASE TO VIEW MORE THE 1024 LINES
currently if you load a terminator table with more then 1024 lines you see TERMINATOR TABLE IS TOO BIG TO BE DISPLAYED instead of seeing it as before.  I recommend you remove this limitation
1 Comment
Amethyst
There is also the issue that there seems to be a file size (looks like number of bytes instead of number of rows) where the system cannot display the table but doesn't know it yet and crashes.  If this happens, just pad out the table with addition dummy lines until it works again.
