Since CREO 1.x Edges behind the selected surface are not shown. Unable to see the geometry behind the selected surface
In Creo Elements/Pro 5.0 and older releases, the edges were shown when the configuration option fasthlr is yes
For future Releases, transparency should work similar to Creo Elements/Pro 5.0.
Reference: CS106063
