1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Metal stamping company, we develope metal stamping tooling.
2. What version of Creo Parametric are you currently running?
7.0.4
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Scale bodies and quilts, should be enhanced.
Scale the whole body or quilt, as a scale factor for all axis, or special scale factors for each axis.
4. What is the use case for your organization?
Create some deformation, for bodies and quilts
5. What business value would your suggestion represent for your organization?
