one of the huge benefits while working with cabling application, in conjunction with schematics system (such as mentor ), is that you get a complete cable in a fraction of time comparing to "traditional method.
However, running a change, ECO, can be quite challenging has importing the new version of NWF file doesn't delete wires/cable that has been REMOVED from the design.
This limitation cause lead to mistakes with novices users and waste of time for veterans.
Having a simple wizard that show Added/Changed/Deleted wire/cable information can automate the process considerably and make it "bolt proof".
This will make Creo superior comparing to other solutions, more robust and easy to use.
