Cables or wires do not show up in Shrink wraps
0 Kudos
Issue:
Issue description:
• When creating skeleton models and shrink wraps from assemblies, the cables are not being created in the shrink wraps. These need to show in the Shrink wraps so that MFG can see reference connections.
Steps to reproduce issue:
• PTC to try creating a shrink wrap of an assembly that has cables.
Expected result:
We expect that if a shrink wrap can be created with harnesses and they show up that the cables should show up as well. It is beneficial that users get all of their model entities in the shrink wraps to convey to MFG what is needed and going on.
PTC CASE - 15641560
