[Cabling] move the RT IN BUNDLES option to the ROUTE DIALOG (instead of the setup menu)
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Marine
2. What version of Creo Parametric are you currently running?
Creo 5 moving to 8 soon
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Ease of use  in cabling UI
It is frustrating when launching a new session of creo, i go to route cables and they get routed outside existing bundles.   I have to cancel out and go to the SETUP and throw that switch every time i start a session.
Can you move it to the  ROUTE CABLES dialog?
4. What is the use case for your organization?
removing wasted time
5. What business value would your suggestion represent for your organization?
remove wasted time
2 Comments
olivierlp
Community Manager
Thank you for your idea and the information provided.
rhahn-2
6-Contributor
A config.pro (default) and/or file (override default) setting.
