Cabling network continuity - Check in "CreoModel"
Case Subject: Is it possible to find below cases using Model Check Tool.
1.if cable network is not created in the Cabling module
2.if the cable Network continuity is broken. - Throw error - "Network is not continuous"
Note:-
Add the above check rule in Creo ModelCheck Quality tool.
Refer the PTC Cases.
PTC Case: C16386209
PTC Case: C16389110
