1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
PTC partner on behalf of a customer designing earth moving machines (excavators, cranes, etc.)
2. What version of Creo Parametric are you currently running?
Creo 7
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Creo Simulation Live is not available while workingh in a skeleton part
4. What is the use case for your organization?
The customer works most of the development phase within the skeleton part. This is the phase where CSL should be available. At the end of the development phase the parts are created by making parts from the skeleton bodies.
5. What business value would your suggestion represent for your organization?
The customer cannot use Creo Simulation Live at the right time in his workflow
