Add the ability to change a dimension name or add a relation directly upon double clicking a dimension.
To change the name:
Double click the dimension to activate dimension edit. To assign a name directly prefix any name with &. For example d1 can be changed to LENGTH by typing &LENGTH
To add relations:
I believe this has also been covered here http://communities.ptc.com/ideas/1018
I agree with the implementation of typing = preceding simple relation input. By typing = can also allow for the selection of other dimensions for use in the relation. In the same way you can do this within cells in most spreadsheet applications.
This will greatly speed up the creation of model intent and lead to reduced design costs. Another benefit would be the tendency to use relations more due to their ease of use, creating more robust models throughout the Creo community.
