Creo Parametric. Change the hexagon sketch that is in the Sketcher mode, Palette. The current hexagon ridiculously has a dimension across one side of the hex. Silly. Instead, update the hexagon sketch to only have a dimension across the flats. This is universally the way all hardware and wrenches are referenced for hexagon shapes!!
