Change Owner on Hatch
If you pick the wrong owner when you create hatching manually (By Polygon), there should be a way to change that ownership. The Move Elements command does not allow moving or transferring ownership of manually created hatching.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
