It would be nice if the default "Creo Files" filter could be modified or if a "User Defined" default filter could be defined. I work with stp files a lot and it would be nice not to have to change the file type filter all the time and instead just add it to the list of "Creo Files" which is the default.
I can imagine that people that work a lot with autocad files might like the same thing for .dwg files for instance.
