The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Change files/folders sorting in File Open window
Right now Creo displays content of File Open window in an odd order when sorted by filename: first there are all folders with names starting with uppercase (sorted alphabetically), then all folders with names starting with lowercase (also sorted alphabetically) and the last ones are folders using non-ascii characters (also in first-uppercase last-lowercase order). It looks like this:
Base
Clutch
Fan
Window
bucket
case
trimmer
Łyżka (spoon in Polish )
łódka (boat)
More natural order of sorting is like this:
Base
bucket
case
Clutch
łódka
Łyżka
Fan
trimmer
Window
and that's the way every other program and Windows sorts it's files.
7 Comments
STEVEG
I could never understand why it is like that.  Dumb.
StephenW
23-Emerald II
Haha, it's a throwback to UNIX where upper/lower case mattered. I think it should be gone too.
BenLoosli
23-Emerald II
Maybe if PTC would quit wasting development money and time on writing OS functions and use OS system calls to things like directory displays, etc. we would see a uniform look to the software. They don't need any special displays as they only support Windows now, so use the MFC calls to make all directory displays uniform.
dgschaefer
Ben, how would the native Windows calls display Creo's multiple file versions?  Would the user be forced to see all the versions on disk, or could it be set to filter out all versions but the latest?  How would it be able to filter *.asm.* from *.prt.*?  I would be surprised if there is a built in Windows mechanism for handling how Creo stores files, thus the need for a dedicated dialog..
PTCModerator
Emeritus
mneumueller
 Idea is Acknowledged and makes  a valid point. While currently not in our immediate plans, this is a candidate on the for roadmap to increase alignment with MS Windows behavior.
mneumueller
Status changed to: Implementation In Progress
this is being worked on for Creo 11.0
