Regarding GOST 2.307-2011 "Unified system of design documentation. Drawing of dimensions and limit deviations"
http://docs.cntd.ru/document/1200086238<https://nam04.safelinks.protection.outlook.com/?url=http%...
4.3 reference dimensions are indicated by the sign "*", and in the technical requirements write: "* Dimensions for reference". If all dimensions are reference, do not mark the asterisk "*", and in the technical requirements write:"dimensions for reference".
In Russian localization for Creo Parametric all references dimension display text "ПРИВЯЗКА" instead "REF" in English version. So, no need extra effort and change a logic of a software to meet russian standards. Need to change localization text "ПРИВЯЗКА" to "*".
