I would like to propose the possibility to change for any existing parameter the type (e.g. for changing a real number into a string) without deleting the parameter and generating a new one.
Reason:
Especially in family table instances it is a very annoying thing if you want to change the type of one parameter which is used already in the family table.
Alternative:
If this is not possible or too difficult, then please allow to rename a parameter.
Current course of action with the current possibilities:
Course of action with the idea implemented:
Course of action with the renaming alternative:
By counting the number of needed steps I think it is rather clear how much work will be saved!
