Change the Colour/Linetype settings of geometry/constructionlines
If i change the colour/linetype of a geometry/constructionline in the workplane settings it should work on the aktive workplane ---> not only on a new workplane
Wenn ich die Farbe oder den Linientyp für Geometry/Hilfslinie in den Einstellungen für die Arbeitsebne ändere, dann sollte diese Einstellung direkt auf der aktiven Arbeitsebene funktionieren und nicht erst auf einer Neuen.
3 Comments
PeterKehoe
The commands in the Settings menus always affect the next items created-not existing items. If you want to change the color/linetype of geometry/construction lines on an existing workplane, you need to use the "Workplane Properties" menu instead.
rschmidt
3-Visitor
Thats not what i want.
Example:
At first i want to draw 10 red constructionlines
then i want to draw 10 green constructionlines on the same workplane
and so on.....
I dont want to change the colour of the constructionlines after drawing
olivierlp
Community Manager
Status changed to: Archived
