Change the centerpoint of a radial pattern (faceset) with relative measurand (R)
If i change the centerpoint of a radial faceset pattern i would like to use the key "R" (relative measurand)
Like the centerpoint of an Machining hole/thread.
Beim Ändern des Mittelpunktes von einem radialen Formelemente-Musters würde ich gerne die Taste "R" benutzen können.
Ähnlich dem Mittelpunkt einer Machiningbohrung
3 Comments
bhug
Regular Member
This is already possible today. You have only to select the plane of the 3D copilot. 3D-copilot_plane.jpg
rschmidt
Visitor
This is what i looking for
PTCModerator
Topaz I
Status changed to: Archived
