Change the default position of reference point of placement, when inserting a table
I am posting this request that I would like to be able to change the reference point of placement of a table, when inserting it by "Table From File"
When creating a new table by "Insert Table",the reference point of placement is decided according to the direction of table.
If inserting it from a *.tbl file, it seems like that the reference point of placement is decided from the setting of original table.
However, after changing the direction from Table Properties and saving it as a new *.tbl file, the reference point is not able to follow the changing of direction.
Therefore, I have to create a new table with desired direction again.
Please check the attached file, which direction is "Rightward and Descending", and I want to place it from the point at the right and upper side.
2 Comments
Dale_Rosema
Xing Jing Chen
You may want to vote on your own idea....
olivierlp
Community Manager
Status changed to: Archived
