Change the default value for drill point angle
Add a setting or attribute in holes tables in order to allows to change the default value for the drill point angle.
Example: Today for ISO standard holes, the value of drill point angle  is 118°. For this kind of hole,  we need for this geometry another default value (140°).
All our tools in the workshop got the angle 140°.
When creating an hole, it should be automatically created with a drill point angle 140° and not like currently 118°. Users can't change this value each time they create a new hole feature.
6 Comments
MartinHanak
24-Ruby II
You can create your own user interface. See AutoIT Hole UI Scripts you may find useful. - PTC Community for inspiration.
mreiter
Thias Idea is similar to Idea 2962 Additional Parameters in the hole_parameter_file.
TomU
Similar, yes, but idea 1294 has been open since May of 2012 and idea 2962 has been open since July of 2013 and nothing has happened yet.
StephenW
23-Emerald II
Nothing has happened? So...business as usual.  Carry on.
Sorry, bad attempt at humor.
TomU
This is now 'Current Functionality' as of Creo 4 M060 and Creo 5.0.2.0 using the config option "drilled_hole_tip_angle".
olivierlp
Community Manager
Status changed to: Archived
