Abobe Message is not easy to understand.
Please change the message for easier to understand.
For Example,
"Security Failure" to "Cannot get the license"
"press the 'Continue' button to save your session before you exit." to "After close this window to press the 'Continue' button to save your session before you exit,save the data to 'file' - 'save'."
"you must wait until they are returned by some other user:" to "you must wait until they are released by some other user:"
