Check Creo major version in modelcheck
Currently, Modelcheck can check what "date code" of Creo generated the file.  The date code is specific to a single build.  I just want to see what version of Creo was used (e.g. Creo 4 or Creo 5).
3 Comments
Sapphire II
With the new naming scheme for Creo 5, is it still returning the date code of the build or does it now give the release build information?
Major release check should be put into Modelcheck.
Garnet
It's still using the old method.  Creo 5.0.4.0 has to be checked at 2018500.
Aquamarine
